Heater turns on automatically and registers high temperatures! Pentair Mastertemp 250
May 27, 2017
5
Canada
Power up the heater and it will eventually turn on to the spa setting! Even more concerning is it seems to register 260 degrees in the heater! Didn't realize until I woke up the next day and the heater was on when it shouldn't have been.
Here's a video of it in action:
https://youtu.be/IHs3ZhH-_VU
The heater was installed new may 2011. (and the date on the machine says it was manufactured in Nov 2008!)
I fixed this yesterday! Turns out my printed circuit control board had some corrosion on the non visible side...so I had to remove the control board to see it. The corrosion was shorting a switch and after I cleaned it with rubbing alcohol, the heater now stays in "Pool mode" and doesn't automatically switch to spa.
