Which heater safety switches cause short cycling? Pressure switch? Temp sensor?
Are you saying that when short occurs, you go switch by switch isolating them or have you gotten to the point where length of short cycle narrows it downShort cycling can be from a variety of reasons. Inadequate flow triggering ps, hls, ags, sfs, bad thermal regulator, flame rectification. If this is reference to the Hayward hd400 post we would need more to help. The loop string is checked upon ignition, if everything checks out and is closed ignition sequence will start. It will monitor loopstring during heating.
It is usually the various over heat safeties.
Short cycling occurs when the heater overheats, the safety opens and shuts it down, the heater cools down, the safety closes, the heater restarts, and around and around it goes.
The majority of the time the overheat is caused by water flow issues not effectively carrying away the heat generated by the
How do you pinpoint the few when a short cycle happens? I’ve been starting with the igniter / flame sensor but besides isolating each safety switch, I’ve never seen a tech isolate one by one.It is usually the various over heat safeties.
The majority of the time the overheat is caused by water flow issues not effectively carrying away the heat generated by the combustion.
I don’t understand. That is based on sensors working properly. I’m talking about sensors triggering a shutdown of a heater because it’s/ they’re faulty.Usually short cycling indicates a sensor is doing its job. For instance some hls will open at 135f and open the switch, it breaks the loopstring and shuts down. It cools and repeats the safety switches are there to protect the heater, doesn’t mean they are bad usually some other problem is causing that area of the heater to overheat.
So you’re saying of the hundreds of heaters I’ve seen, the most common problem of short cycling is associated with your conclusions vs faulty switches before trigger and afterYou are going after the sensor and assuming there is a bad sensor.
I assume the sensor is doing its job and look for the flow problem causing the overheat. Either external with dirty filter or misset valves, or internal to the heater with bypass valve or thermal regulator or calcified heat exchanger.
A sensor failure is rarely the root cause of short cycling.
