So I’ve worked through the other bugs I was having so now I’m on to the next issue.
Gas valve was clicking- replaced
Dirt/dust inside - opened it up an removed burners and blew them out. Vacuumed out the top coil too.
The issue I’m found now is it will shutoff once it reaches temperature (as it should) but will not restart. The light at panel inside the house says it is on but when I go to check it is not. Once I turn off the pump and restart the process, it fires up like normal.
I had a spare ignition system so swapped it out but the problem is still there. What sends a signal telling it to relight and how can I check it.
I have a Laars & Jandy Lite 2 LD400N-L
Thanks
Thanks
