Brand new pool owner from NJ in process of installing our Intex XTR Ultra Rectangular 24ft x 12ft x 52in pool with sand filter and 12 mil solar cover. A few of the common Intex links in the forum are almost 10 yrs old or tough for a newbie to follow, so please let me know if you have best recommendations for a heater for this specific pool that would extend pool season from April to Halloween in NJ.(air temps average 45-60f for spring/fall) What pump/filter should I upgrade to if I want to use a robot vacuum and thru wall skimmer?
Current Progres on install: I had a 20 ft x 30 ft area in our backyard professionally leveled with a bobcat & transit to match lowest area of yard & ground is now very firm compacted NJ native sandy soil that I’ve let settle for 2 weeks. Not adding any type of sand/rock base. Spraying weed killer, then putting down a heavy tarp, then tarp that came with pool, then nine 4ft x 8ft 1/2 inch pink extruded foam base- seams triple taped with waterproof Gorilla tape Putting down 12x8x2 inch pavers level with the ground to support the uprights.
PS: My 17yr old competitive swimmer kid is going to use a swim bungee to train at home in this pool while all the NJ pools are closed!
Any recommendations on heater and filter/pump upgrade as described above much appreciated!
