My in-ground spa is run with Pentair equipment. The water temperature is set to 98F. I noticed today that when the temperature reached 96F, the heater shuts off. After about 30 seconds, it fires back up for about 20 seconds & then shuts off again. This cycle repeats itself without the water temperature reaching the set limit of 98F. The temperature reading on the EasyTouch control panel remains at 96F. I would appreciate any thoughts that you might have as to what the problem might be. Thank you kindly for your help.
