- Apr 21, 2021
- 122
- Plaster
- Jandy Aquapure 1400
Just installed an Aquacal SQ166R heat pump and it's been running 9 hours and not a single degree increase in temperature. I turned it on at 3pm when outside temperature was 75 and sunny. Water temperature was 78. It's now midnight and it's still 78. Temperature over the past 9 hours slowly dropped to 60. Location is south Florida.
The pool is 18x36 with average depth of 4ft. 16,000 gallons. There is an 18x8 sunshelf included in the pool dimensions. I do not have a cover, only a liquid solar blanket that was poured in yesterday.
Pump is pushing 50GPM through the heater. 126k rated BTU but at 80 degree water temperature, 50 degree air temperature, and 63 percent relative humidity it's rated at 82k BTU which is close to today's conditions. Return jets are blowing 5 degrees warmer than suction temperature.
Is this performance expected?
