- Sep 6, 2018
- 76
- Plaster
- Jandy Aquapure 1400
Hello
Looking to extend swim season here in Northeast Georgia. Average ambient temp in Dec and March about 55 degrees (including overnight temps), which would be about the most I would hope to extend.
Through my research here on the site and other sources, I have decided that an electric heat pump is the most cost efficient option for us. We do not have access to natural gas. Propane cost too high in my area. I have also determined that for my pool I need at least 115k BTU heat pump. I got the same number using a formula as a salesman that I called, so i think this is accurate.
But I still have questions. What is the best option for a heat pump to work with my iAqualink? All other equipment is Jandy.
What type of pool cover is best to keep in the heat? Least expensive option.
How can I find monthly cost estimates to run the heat pump?
Would you consider a heat pump install a DIY project? If not, would you know a reasonable install cost range?
Thank you for you advice.
