I bought a house last summer that came with an in-ground salt water pool. I know very little about pools, and until now, everything just worked. The pool has a heat pump (Pentair Ultratemp), which we used on a schedule last summer/fall and it worked well. We used the Pentair Screenlogic smartphone app to set the schedule.
I have a person that comes every week for pool maintenance, and will ask him as well, but looking to learn and maintain my own pool.
Just yesterday, I reactivated the schedule for the heat pump. However, it didn't seem to turn on and the temperature on the pool this morning is not any warmer. After investigating a bit more, I *think* I have a bad pool temperature sensor.
The Screenlogic app shows the pool temperature to be 110 F, see here
The Pentair Easy Touch Control Panel shows the same (so app is correctly reading from the control panel), see here:
I am not sure if the heat pump has its own temperature reading, but the heat pump shows "SET = N/A ACT= 62F" - see here:
I tried recalibrating the sensor using both the SLConfig App and with the Easy Control Panel itself. The app didn't seem to work, and the control panel wouldn't let me set the temperature any lower.
I am assuming it is a bad sensor (assume that means a bad thermistor) somewhere, but no idea where to even look for one.
Any tips, pointers, advice that will make me more knowledgeable is greatly appreciated.
