- Jul 26, 2020
- 247
- Plaster
- Jandy Aquapure 1400
Your heat pump may not be leaking; it may just be condensation draining from the unit.
When heating, heat pumps can produce upwards of 9 gallons of water an hour depending on the temperature and humidity conditions.
This is a natural by-product of the heating process. It is a lot of water too, almost two 5 gallon buckets of water an hour!
So, do you have a leak or condensation draining from your heat pump? The methods below are simple, effective tools to help you figure that out!
METHOD 1
1. Grab your pool chemical test strips or kit.
2. Test for the following items in your pool water: chlorine, salt, and stabilizer levels (be sure to note the levels).
3. Now test the water coming from the heat pump. It shouldn’t have chlorine, salt, or stabilizer in it. If it does, you may have a leak. We suggest trying the method below before calling a pool professional to check for a leak. Sometimes leaks can be hard to find and deceiving as to the origin.
Why is my swimming pool heater leaking? - AquaCal Website
Your heat pump may not be leaking; it may just be condensation draining from the unit. When heating, heat pumps can produce upwards of 9 gallons ofwww.aquacal.com
Great ideaYou could put it in a tray with a line to allow the tray to drain to wherever you want.
They sell drain pans for this purpose or you can make something from available parts.
Master Flow 42 in. x 28 in. Drain Pan with PVC Connector - 26 Gauge 26DDP42X28 - The Home Depot
Drain pans collect condensation to prevent leakage in walls and ceilings due to moisture run-off from primary AC pans. Galvanized steel construction with attached PVC fitting. Locate under HVAC unit andwww.homedepot.com
Yep, that’s my intent with the river rock 3”-4” thick to some what drain it and help it slushy mudBoth my window ACs and heat pump might as well have been showers this time of year.
If you can’t redirect it to a better spot, make that area gravel so it’s not mud.
