later this summer I plan to remove my now defunct mastertemp boiler and replace it with a heat exchanger that is powered by my house gas boiler.
Now my pool pad is about 1m from the outside wall of the house, down one side, so this means I don’t need to have a long run of pipes outside to lose heat.
The house boiler is 35kw which is about the same input as my pentair but it is much more efficient (allegedly) something like 80% vs 95%
So if I’ve got the radiators in the house on then the pool might not get the full 35kw. There’s also quite a long run in the house itself from the boiler to exterior wall but that’s going to be captured in the house as well as the 3ft of pipe that is going to be outside which will lose heat too
Freezing is a bit of a worry but if I run the heating circuit for the the heat exchanger then that should mitigate.
Setting it up to run on thermostat is going to be a bit tricky to automate so will likely be manual. I’m going to use Drayton wiser WiFi TRv heads to be able to turn on which radiators in the house or the pool heat exchanger as wanted. I’ve got a WiFi thermometer probe but that won’t be able to tell the wiser trv to switch off as the latter is going to be measuring the temperature in the pad shed rather than the temperature of the water flowing through the heat exchanger but I think I can live with that. I use i WiFi plug to control my pump and another for my swcg which seems to work pretty well. Again linking them to the wiser trv is unlikely to be possible.
