Thank you JamesW for all your help!!Right now, you are Cat 1 (Non-Condensing Negative Draft), but you are getting condensation, which indicates a bad design.
You probably need to go to Cat 3 (Non-Condensing Positive Draft), which will probably require all new Venting that is airtight and made from better steel.
Technical…Let’s Talk Venting – Raypak
Learn about the intricacies of venting in technical installations, focusing on key elements like water, air, gas, electrical, and space considerations, as well as practical solutions and best practices for addressing common challenges in heater installations.www.raypak.com
The information provided is excellent. Appreciate it.
