Dear All,
Still working my way to being fully out from under the influence of the pool shop.... I have read the old threads on which type of acid to use.
I am unable to find HCL instead of H2SO4 as all my local pool shops only seem to carry H2SO4 based "pH minus"; they all recommend Sulfuric acid, but to be fair to them, they admit that it is because that is what they have.
My recollection from my school years was that HCL is a stronger acid and has a pungent smell, which is why I assume people seem to prefer to work with H2SO4 when possible - marginally safer?
The forum advice to use HCL instead of H2SO4 is as usual very sound and I would like to go that way once my current batch of pH minus is finished (and I am close). Interestingly the last batch of pH minus the pool guy gave me to use with my auto-doser is 45% H2SO4 so pretty strong stuff... I think the laws have changed since and now and they are no longer able to sell more than 14.9% strength.
Since the pool shops do not seem to carry HCL based pH minus, do you have recommendations of what strength I should be using when I find it? So for example, Amazon seems to be selling 14.9% HCL from Bayrol which is ready to use, otherwise I can find industrial use HCL at 30% strength.
I know that chemically is does not matter and that it will likely be a case of accessibility, cost, and safety for handling; but aside from the usual care when dealing with strong acids and bases, are there any other recommendations / reasons for what I should run through my auto pH control system?
Thanks...
Thanks...
