I wanted to install the eye inlet that came with the Hayward SP1091LX Dyna-Skim and replace the one that came with pool. Once i went through the hassle i realized that there was not enough thread to catch so that i could reinstall to my filter pump.I know there has to be a solution and it is probably easy.
Then even though i have been able to run my Auto cleaner off the original outlets using one as an inny and one as out I am not satisfied. I ran the auto cleaner off the sand filter and boy did that run fast.I wonder can i use one of the older rubber connects as a second outlet on the sand filter??? Can I run a fountain if I only have the input off the pump
I know you are confused but so am I
Here are picture of what i have done so far any and all comments suggestions rejections welcome
