Hi All, I had my pool installed last Sept and got a few weeks out of it before closing it for the year. We just opened it and the basket doesn’t seem to be filling on the pump unless I run it on high (3400rpm) for some time. The lines are 2” and the pump is sitting about 30’ from the pool, it is also higher than the pool, I’d say around 6’ higher. The water level at 2600 is just above the intake and seems to stay there at any speed unless priming. I’m having issue with this as the heater says low flow unless close to 3000rpms and even then the basket isn’t full. Shouldn’t this basket be full once primed no matter the rpm? I do have a back flow valve before the pump so as not to lose all the water in the lines when/if the pump is off. Any thoughts? Is it ok that the basket isn’t filling?
