I have a
Water was going down drain just fine. I went to panel to shut off pump and switch valve and there was a burning plastic smell. Breaker at pool area was tripped so was breaker in the house.
Reset both, and now nothing at the pump. the screen is blank. I have good voltage to the pump. Measure 122v on each line in and 244v across them both.
The smell seems strongest at the black cylinder both wires go into before disappearing into pump and maybe I see a little soot.
What is this piece?
Is it a fuse block of some kind?
Is it likely the "cause" of the issue or the result of another issue?
Can I simply replace this piece ?
Thanks in advance
Jim
Hayward TriStar VS Variable Speed Pool Pump W3SP3202VSP
I brought it last year but didnt install until last week. Ran fine for 6 days. Today I lowered pool through waste setting on Filter valve and drained pool for about 10 minutes on 2200 RPM.Water was going down drain just fine. I went to panel to shut off pump and switch valve and there was a burning plastic smell. Breaker at pool area was tripped so was breaker in the house.
What is this piece?
Thanks in advance
Jim
