We have a single 12 volt version of this fixture that was installed 3 years ago and is controlled by cycling the power. It has worked fine until recently when it stopped cycling through programs and now just comes on white for about 5 seconds flickers green and shuts off. You get one additional white blink when power is turned off. Tried the mode check sequence in manual but it doesn't respond with anything other than same 5 seconds of white and then flickering off. Does this match the failure mode any others have experienced with this fixture and were any warranty extensions offered by the manufacturer?
