Hey all!
We are getting a 12x26 ‘Bermuda’ Viking fiberglass pool installed.
The pool builder suggested getting 4 ‘Hayward Therapy Jets’ installed. I am considering installing them like this:
Questions I have though: Does anyone have experience or thoughts on these or other Therapy Jets in a pool? I cannot find videos of the effect.. anyone have such a vid/link? They sound cool, but haven’t found much info, videos, experiences, etc; so any feedback would be great!
Here is the info the PB provided:
Here is the link to the Hayward Therapy Jet so you can see the part.
Fittings Jet-Air | Hayward Residential and Commercial Pool Products
There is two housing assemblies behind the jet. One is for air and the other is for pressurized water.
The air and the water mix behind the fitting head.
I have built 2 ways. One way is to leave a tube out by the equipment that allows air to fill the tube and it will mix on its own with the water. The other way is to “force” air through the air line.
This is done with a Hot tub Blower (Air compressor or air pump). The result is more pressure and bubbles when the water re-enters the pool.
The Jets require the pool pump to draw the water from the pool and push the water back through the jets. The pool pump is not what makes the noise. It’s the compressor which can sound like a small vacuum. I am not aware of any product in the market that is a quiet air compressor or pump. We can only say muffle the sound by enclosing the air pump in something.
The hot tub blower and it is either a Jacuzzi, Silent Aire or Gecko. Most suppliers don’t carry a lot of stock of these blowers so I usually get what they have. I would use a one to 2 hp depending on the number of jets you would be getting.
All comparable in size, noise, quality and price.
And as mentioned, we can build the system without the added air feature if your concerned about noise. Just less pressure.
