I first went to SWG in 2010. I have an AquaRite PRO system from Gold Line/Hayward. The ORP thing never worked well, so I went to a percentage setting instead. (The pH works really well and I'm happy with that.)
Here's the rough timeline of my AquaRite PRO experience:
Overall, I've received at least 3 years since my last T-CELL purchase, so I guess Hayward has fulfilled its warranted use; however, I'm wondering if the warranty replacement T-CELLs are somehow not designed to last as long (it is clearly labeled as a warranty replacement)? If it's not different than the real thing, I'm still concerned that it didn't last at least 3 years and wonder if I have some other problem?
Since my current cell seems to be working when it's on positive polarity, is there any harm in continuing to use it until it fully dies? I figure I can just increase the percentage use, if necessary, to get the amount of chlorine I need. I cleaned the cell with an acid solution last week and it's still behaving the same. The controller alternates between + and -. When it's on -, the volts and amps are low and the salt sensor is way off and the low salt warning turns on. When it switches back to +, it thinks everything is fine.
Date | AquaRite Pro Logic Board | T-CELL 15 |
Feb 2010 | New | New |
Aug 2014 | Stopped working; Hayward authorized repair checked it out and replaced it (it was out of warranty and expensive) | |
Feb 2015 | Replaced with new Hayward T-CELL 15 | |
Aug 2016 | T-CELL not working. Authorized Hayward dealer determines it's defective and replaces it with a warranty replacement T-CELL 15 | |
Apr 2019 | Negative polarity appears be having problems; positive appears to be working |
