Need a little help if someone can lend a hand. Monday we had a huge storm and I had to drain the pool. I forgot to switch back to circulate and ran the pump dry all day while I was at work. we immediately filled the pool and tested and the pump seemed to work, but was scorching hot. Well today I noticed that the pool was greening up so I went to check the panel. The salt level was 0 despite recently adding a couple bags of salt. My theory is that maybe the SWCG cable might have been touching the pump and burned it or the controller up. I did inspect the cable and there are no burn marks or anything to suggest that. The area under the T-15 cell label looks slightly burned as well. I found some old threads and checked the readings. Also, it was difficult to hear, but I did not hear the relay click when it switched to generating:
88
30.6
0.00
84P
-0
AL-1
r1.40
Any help? Thank you
Also, additional info I found just now. I pulled off the control board panel and there is smell of burnt electronics. Thermistor was good.
88
30.6
0.00
84P
-0
AL-1
r1.40
Any help? Thank you
