Hayward Super Pump Problem
Hi All;
Had heavy storms in our area last evening with lots of debris in pool. Pump came on this morning and probably ran with low pressure for an hour or so.
Now pump motor turns on and then immediately turns off and then back on continuing this sequence with a clicking sound.
Help!
Gary R.
Check your skimmer and pump baskets. If OK then cut power to pump and check impeller.
Good luck.
If your suction side is clean and your filter is not plugged, then sounds like an electrical issue. Above my pay grade. Need a member of the forum with more electrical know how or you need to call an electrician tomorrow.
You might search superpump and clicking. See if that dredges up anything.
Take care.
