Below is a video of this pump running at 55%. The top of the video is the suction side. The water level is basically at the top of the water intake pipe in the pump.
New video by Mike Major
Below is a video of the pump after it has been priming for a couple minutes.
The water level in my pump never goes higher than the top of the strainer basket in the pump. After it is "primed" the water level slowly goes down to the water level in the first video. The PB is claiming it is working as expected. I have limited experience with pools but I was always under the impression that pump should run almost full of water. Maybe a bit lower if it running at slower RPM.
Mike
Mike
