Well, I'm stumped. After no problems for years, my solar controller won't auto engage the pump. In fact, it only works when I put it on "manual test." Even then, both the cooling and heating lights are on simultaneously. Confirmed that the nocturnal cooling jumper is in the disable position.
I've changed both the sensors, and now the GL-235 control unit itself, with the same result, same symptoms.
The pump timer is and has always been the simple mechanical Intermatic timer.
Would really appreciate any other ideas on how to further track this problem down and kill it.
Thank you!
Thank you!
