My Prologic has started to periodically turn off, but the main display reads "Communication Error". The transformer was running really hot, so I tested the Ohms and it was slightly out of spec 2.9 and 3.3. As result I replaced the transformer.
The problem is persisting even with the new transformer. I believe the problem occurs only when the salt cell is on. This leads me to believe that I have a bad salt cell or something on the main board power the salt cell is bad. Is there a way to test each of the components so that I can determine which is bad without replacing both?
Or if someone else has had a similar issue and fixed it, please let me know.
Thanks
Thanks
