Hello everyone. I’m really hoping someone can help here. My power flow matrix 1.5 HP started tripping its GFCI outlet the other day. It was out of commission for a full day, then yesterday I removed the front plastic cover and was able to make it work again without really knowing what I did. It worked for another full day, then this morning it is immediately tripping the outlet again. The impeller turns freely. Not really sure how to go about troubleshooting this. It is the model without a capacitor, based on what I’ve seen online. It seems some people are able to rectify this issue by replacing the impeller shaft seal, which I’m not opposed to doing, but the previous owners of the house made it quite difficult to get the pump off the base because they put PVC pipe in place between the skimmer and pump without a union, so I think I’d have to cut the pipe to get it off. Is there anything I can do to troubleshoot the issue while the pump is still on its base? Or is it maybe possible to decouple the motor from the pump basket while it is still plumbed? Thank you.
