I have a Hayward color logic led light, 14 volt, 60hz, 75watt. Its been installed for over two years and when i turned on the light the other day it came on then went dim? I've checked all electrical and the transformer reads 12volts ac, i know the light says its 14volts and has worked at that voltage for over two years.
Now I'll turn on the switch and the light will work for maybe 30 seconds then dim and will go dark, i'm not sure whats the issues are or how to fix this issue.
Thanks
Bruce
Thanks
Bruce
