Good morning, new to the forum but had a question to see if anyone has had the same issue. Fired up the new all Hayward system for the first time and the pool/spa main pump is a Tristar950, operated just perfect wired into the OmniLogic. My second pump for water features is located in the HUA no problem but once it kicks on it will only run for 10 seconds or so and stop pumping, control shows it as still on but not running, don’t trip or anything. Can switch off and back on and does the same cycling. Did a reboot and power down and it will run and cycle the speed down and back up at random. Powered it down again and now back to 10 sec run times….when the water bowls are turned on with the same feature pump they stay running but the pump occasionally drops in power for a second and picks back up, when I turn the tanning shelf bubblers on the pump does it’s 10 seconds on and turns off. The feature pump is wired identical to the pool pump, so trouble shooting I disconnected the automation from the pump and operated straight from the pump control panel and it was all good. Can’t figure out the low volt communication issue going on with my second water feature pump, any help is much appreciated.
Mike
Mike
