Hayward OMNI operating PENTAIR SUPERFLO VS 1.5 HP (2.2 THP)
GaryinMiami
14
Miami
Hello my pool guy wired the VS pump on the “LOW” speed portion of the Omni. I assume this because the pump only comes on when LOW SPEED is selected on the APP/Controller. This seems ok but on the APP when I set the schedule it doesn’t turn on. Only when I open the app turn the schedule off then on does it activate. Or just selecting LOW SPEED on the APP… I’ve programmed the speeds/time on the Pump. Any help is appreciated getting automated activation would help. I was trying to just leave the pump on in the APP and program the times/speeds on the pump but no luck. Thanks.
Which OMNI system are we discussing?
Your pump should be wired to the filter pump relay.
Show us where your Pool Guy wired your pump to.
Sorry for my ignorance in not posting more info.
Pictures of the panel below. 4 wires from the pump. Black, (line in) Red (is capped) green (Ground) Orange (AUX)
I’m ok with programming the pump spores/time. My issue is the Omni doesn’t activate the pump unless I manually select LOW or turn the schedule off then back on. It then functions perfect.
If you want to run your pump as a single speed pump on its low speed then I would move the Orange AUX wire from AUX2 Load Out screw to Filer Pump Load Out Screw, that has nothing connected to it.
Also remove the other three wires running from the Filter Pump relay to AUX2.
Then change the Omni Configuration and say the pump is Single Speed, not two speed.
As it is setup your Omni thinks you have a 2-speed pump and it gets the pump running on high speed from the Filter/Pump and then you need to change it to low speed.
