I thought it was not enough suction but then I used the pressure gauge and pressure is fine. The pods and flaps move like a beast when suspended and I removed the weight on the hose as well thinking the hose is weighing it down. I lift the hose to aid its movement and it moves fast then slows, fast then slows. I do not think it is suctioning itself to the pool bottom because I have tried reducing pressure. I assume I may need to change some parts - I am just not sure which parts would create this issue. I did replace the pads and wings so I know those are not at issue. Any suggestions? Thanks.
