The blue 7-segment LED modules on my Max-Flo VS (SP2300ZLV) display have aged and become unreadable. This made programming the unit virtually impossible. Fortunately, replacement LED modules are cheap and readily available! The existing modules are attached via plug-in sockets. Replacement took about 15 minutes.
The obsolete part number on the existing modules is ELS-431UBWA. I researched a substitute and ordered the parts from Digikey PN: 732-157119B12701-ND.
You will need 5 modules, total cost...$12.75.
There is a 3V, CR-1632 lithium battery installed on the programming board I suspect is for retaining the programming. I replaced this as well.
