Hayward Max-Flo VS Pump- Display Problem
lifetimepav
3
Portland, OR
Hello! My name is Pavel and I have a problem with my MAX-FLO VS Model SP2302VSP. The control panel stop working properly, mainly the on/off button and some of the other as well. So decided to see if the whole panel is available to purchase as a replacement and only ones I could find were for newer models and quite pricey. While I was looking I discovered you and it seemed to me you know quite a bit about the subject, so I decided to contact you. Any idea if it is fixable(the original panel) or where to purchase new panel? Any help is greatly appreciated! Thank you so much in advance!
Make that a 3rd owner. Unfortunately, I won't be any help. I also looked at prices for a panel replacement and I finally just to get a new pump, which was installed yesterday.
For anyone else with this problem, I wanted to note that eventually the power button became so flaky that the pump began to turn itself on and off. I ended up unhooking the display from the unit entirely and was able to run for several months until I was ready to buy a new pump.
  • Wow
Reactions: Texas Splash
Welcome to TFP! :wave: Your the second owner today I noticed with a similar problem. Did you make any progress yet, or do you still need some help?
Yes I do. The pump works fine. The on and off button does not work pretty much at all, the rest of them seem to be working. I have been operating with on/off switch for power that we have by the pump. It is not ideal at all and have a feeling that it wont last like this. Thank you for any and all info about the panel. Can not find it anywhere!
