So my first question is does anyone know the brand or part number for this filter? I believe it is Jandy but it could be Hayward.
Now for my problem there is a leak at the inlet bulkhead union and I just replace all the o-rings with new ones. Air is being sucked into the system and I cant seam to stop the leak. There is no crack in the piping so I cant understand why it is leaking. The o-ring has to be replaced from the inside so it sucks to replace. I don't believe I over tightened it. Is there any type of sealant that I can put around the inlet to ensure it does not leak? I know I need to use a teflon type sealant and I can't use a Vaseline type sealant. This summer I will replace the filter housing with a new system but I don't want to damage my pool equipment so I would like to fix it asap.
Any help would be greatly appreciated!
Here are some pictures of the leak and my equipment.
