So here is my situation. Im an electrician and am wiring this heater for a client tomorrow. He currently has a 120v filter pump controlled by an intermatic digital timeclock with no automation. The Hayward HP-50 requires a 240v 20a circuit ran to it but if you look at the wiring diagram there are also 2 terminals for filter pump enslavement. I cannot find anything that explains this online. What im assuming it means is that you can wire you filter pump through the same feed that your feeding the heater with and daisy chain from circuit breaker, to disconnect, to heater, to filter pump. Only problem i have here is the filter pump is 120v and certainly cannot wire that through the heater. Has anyone installed one of these heaters before?
Here is the link for the manual.
https://thepoolshoppe.ca/wp-content/uploads/2014/03/hayward-hp50a-heat-pump-manual1.pdf
