- Jun 15, 2016
- 4
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
I purchased a Hayward HD100ID1 propane heater 3 years ago, and after a week of having it on this year, it started producing a lot of vapor and appears to have an internal leak. I am assuming the heat exchanger is leaking and have shut of power and gas. I am purchasing a replacement, but I would like to know if it is expected that water chemistry could cause this rapid deterioration of the heat exchanger.
Looking at the heater manual, it recommends the following levels:
CL: 1-3
pH : 7.4-7.6
TA : 80-120 ppm
CA : 200-400 ppm
Salt : 2700-5000 ppm
My pool chemistry in the last week has been :
FC : 6.5-8.5 (opening I overshot with liquid chlorine)
CC : 0.0
pH : 7.2 - 7.3
TA : 50
CH : 0 (fill water is post-treatment due to lack of bypass plumbing, and the treated water is very soft)
CYA : 60 - 70
Salt : 2700 ppm
The heater lists the effect of low levels for CH as "corrosive to heat exchanger".
I have always left the heaters out over the winter with the plumbing removed, but the gas line connected.
Should I try to get my CH levels up to 200 ppm prior to installing the new heater?
Which other levels would contribute most to corrosion?
Should I disconnect and move the heater inside for the winter? I have hesitated to touch any gas fixtures out of an abundance of caution, but if it is simple union to disconnect and then reconnect in the spring, I would be willing to do it.
CL: 1-3
pH : 7.4-7.6
TA : 80-120 ppm
CA : 200-400 ppm
CC : 0.0
pH : 7.2 - 7.3
TA : 50
CYA : 60 - 70
Salt : 2700 ppm
