Hi Everyone,
I have a Hayward Heat Pump that has been misbehaving. A few weeks ago I had a service tech put it through the paces but during diagnosis the 1 AMP fuse burned out and he didn't have one on the truck. He's scheduled to come out this Wednesday. I ordered some 1 AMP fuses to have on hand, pooped one in and it came to life. It has proceeded to display the following behavior.
Cold mornings mid 50's to low 60's won't come on and displays error code LP for low pressure.
Cold mornings mid 50's to low 60's starts up just fine.
Turn down requested temp and unit doesn't not shut off.
The unit is putting out air that is 8-10 degrees cooler than ambient temperatures, and it is producing about 1 degree per hour rise in temp when running.
Today it has been running non-stop since 7:30 this morning and it just cut off. The only thing i noticed upon inspection is that the fan motor casing (very top of unit) is 125 degrees in the shade, it's 84 outside right now, seems a little on the hot side but I've never checked it before. I only checked it because after turning the breaker off and on and waiting for the ~5 min. delay I can here it try to turn on, but the fan doesn't turn on, and then it displays LP.
Manual says if LP is displayed to check for airflow blockage, but this is giving me the LP error code before it starts running. The Tech did not hook it up to gauges to check as we could get it to operate after the fuse burned out. The coils and fins look like they may have some green growing on them and I certainly could clean them with a hose. It seems to me like maybe the fan overheated and that is why it stops. It's done this over the past few days and I'll go out to check and it will be running again.
I'm just trying to be able to give my tech something to work with so he doesn't waste time like last time with the lack of fuse. If it needs a fan motor I'd like one on the truck etc.
Many thanks for any input!
