I recently replaced the heat exchanger in my pool heater due to it leaking, easy replacement. After getting the unit back together, I fired it up, it started fine, but would shut down after seconds, sometimes 10 seconds, sometimes 35 seconds, it fluctuated, but it would start back up on its own after about 30 seconds. It did this over and over with no trouble code ever coming up on the display. I had a pool guy come after I could not figure out the problem, he thought it was the flame sensor so he replaced it, still have the exact same problem. His next suggestion is to try and replace the main circuit board but has no idea if this is the problem or not. I do not want to keep spending money on things that don’t fix the problem. The unit was working fine even with the leak prior to the heat exchanger replacement. Any suggestions as to what the problem could be?
