- May 24, 2015
- 101
- Plaster
- Hayward Aqua Rite Pro (T-15)
Giving this thread a bump as I am experiencing the HS/LO codes now too, exact same issues. Heater goes until 85-90F then throws HS code then LO code.
Bypass valve is closed so water should be full pressure into heater
The Hayward SwimClear filter (8) pressure shows fluctuation between 11-12PSI when pump running. Is that too low time to clean filters?
Moved from here.
Moved from here.
