- Aug 16, 2022
- 133
- Vinyl
- Zodiac LM3-24
I am getting a LO alarm which I understand is related to flow and affects the PS. Here is what I know,
With flow through heater
1 - PS is open circuit when checking continuity on the PS connectors. Should this be closed with pump running?
I can verify flow as I have a check valve on the outlet of the heater and it is clear that there is flow.
No change of condition when the heater is bypassed (3 way valve on inlet).
Is there a way to jumper these to verify that my problem is the PS?
Anything I should try before moving on a new PS?
