Hi all,
This is the third season for our pool & heater. It's a 12x24 above ground vinyl pool and a Hayward H100ID 100,000btu heater that gets fairly heavy usage. Upon opening last weekend, we started hearing some noises that we had not heard before.
The first thing I did was check my warranty, but it was only a 1yr, so that ship passed. Time for some self-diagnosis and online research.
Initially, I thought it was the draft blower - a dry bearing, but I pretty quickly eliminated that as the source. After doing some online research, it seems to me that it's either a broken baffle or scaling in the heat exchanger. The unit in question does not have any separate diverter valve, it's all integral to the heat exchanger.
Some things to get out of the way:
I found another thread that was very similar to my problem: Cavitation when my heater starts
Unfortunately there was no clear outcome that the descaling fixed his problem.
I also found this: Hayward pool heater noise - DoItYourself.com Community Forums
Although there was no resolution, there was a link to his video that captures the sound very well. It's exactly the same sound:
And finally a video I made of my unit this morning, though the above linked video has better sound.
I fear that calling out the local gas man (Already a $100+ affair) is just going to result in a heat exchanger replacement, or a heater replacement, when all I need to do is descale the heater.
If I were to attempt the descaling, I would need to adjust the water plumbing a little as there is no bypass or disconnect plumbing. This is something I can do myself. I fear it will turn into a rabbit hole of expense if I get the gas man in...
Any thoughts? Do you think this is scaling? It seems I can't find much about this happening online. The company that installed the pool say they have never heard of anything like this before.
- I have backwashed the filter and the pressure is as good as it's ever been (14psi)
- I measured the flow at the pool inlet to be ~30gpm. The heater requires a minimum of 20gpm. The flow at the pool seems as strong as previous years.
- It seems to occur more when the water temperature is higher (so it did not do it as much when I tried filming it this morning, typical)
- I have been following the BioGuard chemistry system, taking water samples into my local pool shop every week or two. I have saved all the history and am willing to go back and check anything if needed.
- Typically, the PH is high (7.7 - 8.1 - sometimes a little higher sometimes lower, usually below 8) and I adjust it using their Lo 'N Slo product following their instructions.
- Typically, the Alkalinity is low, ~100 +/- 15. Again, I adjust it with the BioGuard product (Balance Pak 100) as per the instructions.
- I don't see a CSI anywhere on the reports. Only a 'Total Hardness' which seems to stay around 194. It was lower for a while last year at 113-170 in July. Rectified with Balance Pak 300 . In 2018 (The first year) it seemed to be more like 270
- Most related problems seem to complaints of banging and rattling noises, usually attributed to the internal baffle coming loose. Although this could be the problem, I do not hear any such noises.
