Freeze protection worked fine for most of the winter. This morning I woke up to 36 degrees. The controller says that freeze protection is on. The pool and spa lights came on for the freeze protection just fine, but neither of the pumps (main pump for pool/spa and separate pump for waterfall) are running. Because of the freeze protection, the buttons on the controller are disabled. I tried putting the panel in service mode and then back to normal to see if that would reset it, but nothing changed. Lights are still on, but no pumps. Any ideas on what is wrong and how to fix it?
p.s. I know nothing is going to freeze at 36 degrees, but I am concerned that it isn’t working properly and want to get it fixed so I don’t forget about it over the summer and then have a problem next winter when we need it.
