Hayward fitting size
Apr 28, 2013
39
GSO, NC
Posting here before I begin my google search. I accidentally kicked and broke the small plastic fitting at the base of the pump. Hose connects to the top of the filter housing. Is this a piece I can get from Lowes/Tractor Supply, or dare I say Leslies?
[I'll add pics in a few minutes]
2 pics uploaded.
Its next to the drain; now its broken and acting like a drain :mad:
So I dont need this 'pressure relief hose'? If I can get the correct fitting, it will be easier to replace that. Otherwise I'll have to plug the other end (tee'd into the pressure gauge fitting)
Wow, found one those in my brass bin, and some 1/4 NPT plugs. The o-ring squishes out, I will need a big washer, and the hose is a b!tch to get on past the tip.
I'm gonna see if I can locate the correct union before plugging both ends.
Reactions: JamesW
Does it matter which way it goes on? I never noticed FRONT, I guess that would be pump inlet?
I usually put ithe cover on 'backwards' which puts the handle near the pump outlet, so I can place my foot near the pump base (99.9% of the time avoiding the ozonator fitting) as I step over the pipework to get to the controller. The controller is in a real bad location.
