I am having an issue with my EC50 above-ground pool filter. It seems to have a leak somewhere but I don't see anything obvious. What is happening is that when I first turn the pump on, the water return will shoot DE back into the pool for about 5-10 seconds, maybe a little longer. I'm guessing that the reason that it stops is that whatever leak is there gets sealed by the DE re-coating the filter internals once the pump is running. I've seen some discussion of this regarding grid style filters but since this model is designed differently, I'm hoping someone has some experience and suggestions as to specifically where I should look for leaks.
I also have a few other questions regarding repairs.
- I have seen that for some Hayward filters you can replace individual filter tubes instead of having to buy an entire assembly which ends up being pretty expensive but I don't see any individual flex tubes listed at my local pool store so I'm trying to understand if that is an option for this filter, should I find that there is a busted tube.
- I know that there is a gasket that could be the culprit but I'm not 100% certain how to get at it to check it. I'm assuming that I will need to disassemble the lid, is that correct? Is the gasket visible just by taking the lid off the filter?
- Are there any other gaskets or parts of the filter system that I should look at? I seen multiport valves mentioned a lot but I don't think my filter has one.
