Hayward Aquarite low salt chlorinator - Help with cell selection
PLB27
2
Canada
Hello everyone!
Purchased a home with an inground pool two years ago so I'm still new to some of the maintenance and products.
The pool is equiped with an Hayward Aquarite "low salt" chlorinator. I am in Canada where this version is sold.
The cell is now 7 years old and just wanted to get ready for when it dies. I am currently running on an "old" t-cell-ls9-cul which is the equivalent of a Turbo cell 9 but for the low salt version of the Aquarite panel. At least, that is my understanding.
My question is : can I replace the low salt cell with a regular turbo cell 9? The dedicated low salt version of the cell is 300-400 more expensive than the "regular" one.
I'm thinking the regular cell would work fine as it is probably the board that makes it low salt, not the cell. Am I wrong? Would appreciate any other input
Thank you!
Welcome to TFP.
Low salt cells are simply larger cells run at reduced output.
A t-cell-ls9-cul is a relabeled T-15 and costs as much as a T-15 due to the plate sizes.
A regular T-9 does not have the plate size to give the same chlorine output as the t-cell-ls9-cul.
You can change your controller to run in regular salt mode with a T-9 cell.
How many gallons in your pool?
Welcome to TFP.
Thank you!
My pool is an inground with 25k gallons!
Welcome to TFP.
Does a Hayward Low Salt cell have to run on a Low Salt controller or can it be used on regular AquaRite/SwimPure+/AquaLogic controllers?
Hayward has started chipping their cells. I don't know if a low salt cell is any more then a label on a regular cell.
We have no reports yet of folks connecting a low salt cell to a regular controller.
I have the same issue as the OP.
Seems the new Low Salt cells don't specify a number anymore (T-CELL-LS-CUL instead of T-CELL-LS9-CUL)
If I buy this cell, which setting should my control box be set to? t-9 or t-15?
I have the AquaRite AQRXL-LS-20CUL (for up to 20k gallons). My pool is ~10.5k gallons.
Thanks!
If you can count and measure the plates in the cell...
T-15 has 13 Titanium Plates, 150 x 63mm. Produces 1.47 lbs/day.
T-9 has 13 Titanium Plates, 101 x 63mm. Produces 0.98 lbs/day.
T-5 has 7 Titanium plate, 150 x 63mm. Produces 0.735 lbs/day.
T-3 has 7 Titanium Plates, 101 x 63mm. Produces 0.53 lbs/day.
