My pool is 3.5 years old. I noticed my pool seemed to be having problems keeping the chlorine up in the pool. I was running my generator at 90 percent and was still seeing my levels slowly drop.
To make sure it wasn’t something in my pool, I did a OCLT (overnight chlorine loss test) and verified my readings at sundown with the pump running all night (generator off) matched my readings at sun up - nothing is eating the chlorine.
So I did a salt test on my pool (drops) and noticed there was a wide gap between what the panel was telling me vs. what the drops told me. The panel is reading much lower - to the tune of 600-800 ppm depending on the variability of my salt tests. So after reading some more I did a muriatic acid clean of my cell (it wasn’t crusted but I did it anyway) and still got the same results. I assumed the cell went bad so I purchased a new one from Amazon. The box is genuine and the serial number on the cell indicates it was born in 2018.
Plug the new one in, same low salt count after 24 hours.
I verified with 5 different salt tests (drops) in my pool, I purchased new reagents to make sure my results weren’t sqewed by old reagents. I even took a salt test from the pump basket water because that’s the most mixed water I have. My tests are showing much higher salt then my board is telling me.
The cell is a T15. Verfied just now that it IS making more chlorine then the old one I pulled.
Is it possible my board is going bad? Do I need a service call? Or should I just dump more salt in my pool?
Board readings
3000
85
25.1
5.85
1.59R
00
T-15
Thanks Gang !
Board readings
3000
85
25.1
5.85
1.59R
00
T-15
Thanks Gang !
