Hayward AquaRite 3 Turbocell 3
astew
8
yulee, florida
Hayward Aqua Rite (T-3)
Not generating chlorine plus not reading salt level. I have reset everything I can think of, but there is one I can't figure out if it is a problem or not. So my display order is average salt level; cell voltage; cell amperage; output; instant salt; program code; product version; cell size. Average salt is wrong, temperature is dead on with in-pool thermometer; voltage is 30.3; amperage 0.00 (other polarity is 0.08); output shows were dial is set; instant salt -0; program code AL0-5; version r1.59; salt cell is t3. Question is if the program needs to be set to 3 since it is an aquarite 3? or would this even make a difference. My salt at the pool store was 3700.
I was about to start treatment for mustard algae when I realized there was a problem. Help.
Is your Aquarite connected to any automation?
AL-5 is used with Jandy automation.
AL-0 is AquaRite.
Move the switch to auto and momentarily push the diagnostic button to display the Product Name "AL-X".Then move the switch to Superchlorinate and back to auto 3x or until the desired AL-X is shown on the display.
Pressing the diagnostic button sequentially will display:
  • Default salt display
  • Pool temp
  • Cell Voltage - When not generating, the voltage is about 30 to 32 volts dc. When generating, the voltage drops about 1 volt per amp of current.
  • Cell current
  • Desired output (% of the knob)
  • Instant salinity
  • Product name
  • Software revision (r.XX)
  • Cell type
This is the basic information we need to know in diagnosing a problem:
  • Report all diagnostic readings when you..
    • Move the switch from auto to off and check all of the readings.
    • Move the switch back to auto and recheck the readings.
    • Move the switch to off for a minute and then back to auto and recheck the readings.
  • What are the first seven characters of the cell and box serial numbers?
  • What is the actual salinity and how are you measuring it?
Post pics of your control box and cell.
AL-0 is AquaRite.
  • Pool temp
  • Cell current
  • Instant salinity
  • Product name
  • Cell type
Thank you. Found that my cell was dead. Was able to get it replaced under warranty by my chinny-chin-chin!!!
