Hayward AquaConnect "Lost link" and Unit not communicating with cloud server
Aug 26, 2016
17
Atlanta, GA
Hello all -
I hope everyone is staying safe during these trying times! I have an issue with my Hayward AquaConnect system. I noticed on the phone app a "lost link" message and then logged into the AquaConnect website where the "Unit not communicating with cloud server for xx days" error was showing.
I'm fairly technical and have a good understanding of networking and ran the troubleshooting steps. The device is connected via RF to the panel, and after performing a signal test all 4 lights illuminate. I replaced the network cable and plugged it directly into my router to bypass any of the house network.
I have tried to connect to the local IP number of the device to use its webinterface. I can get a connection however its slow and times out. It will control the pool but is not reliable...appears the connection to the Hayward gateway is intermittent.
What's wierd and normally the RF, TX, and RX lights are solid and the Link light flashes every few seconds. Since this I've noticed this issue the RF and RX lights are steady, but TX is flashing in a rapid but not constant pattern. The link light never lights up.
I tried to call Hayward but they didn't seen interested in helping and referred me to a dealer. I have not yet called a dealer as I suspect (1) a service call will be needed and I really don't want someone in my house right now or (2) it will be a "this device is out of warranty" discussion. Looking on Amazon the gateway is $500...which seems crazy expensive.
Any ideas on a resolution???
Thanks all!
Chris
Did you reboot the AquaConnect? Flip the CB off, wait 5 minutes, and power it back up?
Link light should be blinking.
page 11 says...
ACHN is not communicating with the web site and the LINK LED is OFF. Even if you aren’t using the web site or the local server, the LINK LED should blink ON at least four times a minute. Verify that the Internet connection to the home hasn’t gone down. Try logging on to the web site to make sure that the web site isn’t experiencing difficulties.
Try redoing the training beginning on page 1.
Thanks for the link and the additional thoughts! I've powered off the panel, waiting about 10 minutes (while I did my water chemistry check) and proceeded with the training instructions.
Was able to get a successful "teaching" completed, the moved onto the range test...which passed with 3-4 lights.
Still no-dice with the link. The local server option is kinda working. The page will come up and the status is mirror on the front-panel, see attached picture, but the controls do not seem responsive.
I took a quick video of the lights:
Any other ideas?
Thanks in advance for the help!
Quick update - I may have figured it out!!!!
About 12 days ago I switched my router to use 1.1.1.1 as the DNS provider rather than the default DNS provider. Looking back that's when the portal is reporting lost link.
I reverted the router settings back to the default and after unplugging the AquaConnect gateway the link link is blinking again.
The app and website are still showing disconnected and the Link light seems to be blinking some type of error code.
Its blinking 1-1-2
One blink, off for a second, One blink, off for a second, 2 blinks......repeat
I feel like I'm getting somewhere, just not sure how to re-establish the link and or clear this blinking code...
I would go back to square 1 and redo the teaching.
Thanks ajw22. Looks like once it stayed connected long enough the errors cleared by themselves.
Seems to be some issue with the DNS settings the Hayward/Goldline unit is looking for that CloudFlare isn't supporting. Strange. Perhaps when I have time I'll do some network sniffing to see what hostnames the unit is trying to resolve and log a ticket with CloudFlare.
We see a bunch of automation systems that can't connect to the net after router changes. It has mostly been due to IP addressing problems but you may have discovered one of the other causes with some popular DNS services not working with the antiquated ways of pool equipment.
Yup, I've stumbled into this with other building automation products. I ended up creating a local network at the house just for the Hayward unit which leverages the default DNS provider and then moving the rest of the network back to CloudFlare. CloudFlare has some nice features with Malware and Content blocking that comes in handy with having little eyes in the house. Everything seems stable now, fingers crossed!
Wow! This helped a lot. I had exactly the same problem (“link lost” and I recently switched to Cloudflare DNS server). I have been struggling with this problem for days and days. Thank you!!!!
Same thing seems to have started happening with google dns as well.
Soon no public dns servers will support whatever type of dns the device is sending.
Maybe sending large tcp dns packets? Makes no sense why tho. Unless the internal software was developed really crappy.
Old link hope someone can post a DNS which will work as I have the same problem and am using AT&T at home no link
@@@ resolved by Hayward deleting my mac and readding there side to there database
Since a few days my device cannot be accessed neither by remote via internet nor by local webinterface.
The web interface seems to reload continuously and only the screen and the 5 arrow buttons with appears. Screen remains empty.
All other buttons do not appear so no system stop no filter no aux.
Switching off for multiple minutes is not helpfull. Oh yes one week before I changed something on my Router, and I had for a long time already DNS 1.1.1.1 I changed it to 8.8.8.8 no effect, now it is from Provider. Provider is Quantum. Now I switched the device off.
Does anyone has a suggestion? What can I do? Or what happened? The MAC-address of my device is still the same. In the last days, it was really hard to make readings and writings aka change settings.
Oh by the way I have a Hayward Goldline Prologic PS-4.
Thanks
Hi there just a theory yours sounds like could be internet speed to and from the controller and to the web and back
I would suggest
1. leave dns as per we provider
2. Move Hayward devices closer together as it sounds like with the web page loading slow may be congested internet
3. Restart you internet
4. Try to have the Hayward remote controller plugged into your modem or a repeater
5. Have you added more devices or users to your internet
I would ask you internet provider to check your internet then have a ticket with Hayward
Ok. Sounds interesting. I have 500/500mbit/s up/down
I think that should be enough, even if there remains 1-300
I would suggest
I left it already, before, but no change. Will test the device later again.
Maybe
Already restarted 3x
It is directly in my modem. Was working I think more than 1 year. In the same location and position. Also for a year on double NAT.
I am the only user
Ticket at Hayward? Can you provide me a link? Please
A day ago I tried to contact them, but their system wants everything address name Phone E-Mail they only didn’t ask for my girlfriend’s name and how real I am
But it did not accepted the address, so I canceled that try.
Could it be a hardware issue?
Thank you very much for your response
Only to tell what happened next.
I have no physical access to devices. I am not at home.
But I can switch off the device by remote. for reboot purposes.
So I switch the remote interface off. I wanted to have it switched off for a week or so. until next time time i need access. I forgot to check that switch for automation. And time logging in, I found out, it is already up and running. So it happened that after about 18Hours of being switched off it was switched on and it was running like before when i wanted access about 3 days later.
So for now everything is back and ok.
Maybe it was a ipv6 problem behind my router. I do not know. But something curios happened to one of my raspberrypies these days. while ipv6 on, i had no acces to ipv4 and my raspberrypi from another network segment over ipv4.
But thank you for your ideas.
How can I get in touch with hayward support and development connected with this network2pool device?
