Hello: Have a Hayward 1200 StarClear filter system installed in 1999. Today, the housing drain plug blew out (old age). Trying to replace it but the part, # CX250Z14A, does not fit, it too blows out under water pressure. This is the same part # of the plug in the 1200 model installed in 1999, but I am pretty sure Hayward redesigned the 1200 model housing, the ones on display in the retail pool stores are slightly different in design. So in my opinion, the hole where the drain plug screws into also was redesigned, thus why the correct part number does not work in a 20-year-old model 1200.
There's got to be an older drain plug out there somewhere waiting for me! Please don't say I have to purchase a $365 model 1200 filter housing (or any other new filter for that matter) when the one I have works perfectly well (plus installation cost, of course),... other than there's no drain plug, for now, that is.
Hayward "support" has not been much help, except to say I have the correct part number. Yes, I know that, ...
In the attachment here, you will see a drain plug from a 1200 Hayward on sale on Amazon. Take a look at the plug's edges. They are not the same as this one , which is the currently designed plug CX250Z14A. I am fairly certain the one in the attached pic is closer to what I need from 1999, and yes, I know the part number is correct for the 1200. Take a look at the edges of the plug in the link above you will see the difference, it has tabs of sorts, that is not the one I need. My older model housing's plug is more of a smooth edge, no tabs at all.
Ideas? Thoughts? Solutions?
Thanks in advance....
