hayward 1.85 pool pump
Huckabym
1
Huck1224$
Jandy Truclear / Ei
I have a Hayward 1.85 THP VS Tristar pump. I'm only using the display that mounts on the motor and no other controls.
The pump was not running so I go and flip up the little lid to see if something is wrong and there display is not showing anything. I used a volt meter to check power all the way to the circuit board that is on the motor.
I also tried to check to see if there was 12VDC where the connector for the display would be plugged in and there was nothing.
