Hi all,
Three weeks ago I drained approximately 80% of my pool water due to high CYA level. Since then I have been getting the chemical levels back in balance. So far so good with everything except the PH level. Following pool math, reading Pool School and checking chemical levels daily, for the life of me I can’t get the PH level within the 7.2 - 7.8 range. I have added at least 3 gallons of muriatic acid in the past 3 weeks. Readings as of this afternoon are:
FC 4
PH 8 but it could be 8.2
TA 90
CH 250
CYA 70
Ive turned the bubblers off to reduce aeration. Should I keep adding the acid or is there something else I should consider doing?
thanks for the help
FC 4
TA 90
CH 250
CYA 70
thanks for the help
