- Sep 22, 2011
- 211
I have a DE filter. In past season, I would backwash maybe once per month. For some reason, lately I've had to backwash every five days. Basically, I notice that the water pressure out of the return jets is diminished. When I check the filter, the pressure is up to 24 PSI. After I backwash, it drops to 12 PSI before I add DE, and then about 14 PSI after I add DE. The water pressure is restored after I backwash, but then about four or five days later, the pressure goes back up to 24 PSI and I have to backwash again. Any ideas? I suppose I should take apart the filter and see if anything weird is going on.
Kevin
Edit: I should note that the pool isn't getting any more use than usual.
Kevin
