- Nov 8, 2020
- 20
- Plaster
- CircuPool RJ-60 Plus
After years of fighting my pool to keep it clean (it had a 2 speed pentair pump, stainless 24 sq ft DE filter, polaris 280, using chlorine tablets), I found my filter was way undersized, so I bit the bullet and upgraded all my older equipment by installing a Pentair Intelliflo pump, waterway 525 sq ft cartridge filter, Circu-pool RH-60 salt chlorine generator and a Dolphin s200 robotic cleaner (most were selected based on recommendations I found on TFP).
I'm an energy miser and currently run the intelliflo at 1250 RPM on skimmer for 7 hours per day. I'm running the salt chlorine generator at 55% and let it turn on and off with the flow switch. I check chlorine level every few days and it's staying right where your training states (I had to adjust the salt chlorine generator up a little to get it where it should be). I have the robotic cleaner run for an hour every day. My filter pressure gauge reads zero (because of the low pump speed), but every week or two, I spin my pump up to 3000 rpm to check the pressure reading so I'll know when to clean the filter. I use powder shock about once per month, but the shock doesn't seem to improve how clean the pool already is.
The pool is staying clean as can be, but I'm wondering if I'm being to miserly.
Second question is that I have a few friends who have single speed pumps. I'm wondering what you people think of the cheaper VSP's out there (Black and Decker, etc) and what VSP is recommended that won't break the bank.
